I have recently done a drone survey of an area with buildings and roads. The point cloud seems good, although having alot of additional points in the sky and surrounding areas (as ive had the camera on the drone set at 65 degrees and not directly down). I have edited the point cloud to remove all of the unwanted points but the mesh is still connecting to reflections in the sky and showing an unusable mesh. Is there any way of re processing the new edited point cloud points to create a new mesh which i will be able to use?
Any help would be great. Thanks
