Without deleting data but assigning points to group “deleted” then regenerate 3D mesh with specific groups selected in order to produce a clear mesh . However
after regenetated mesh , sames the new mesh model is the old
one nothing changes .All help is greatly appreciated!
Hello, would you please make sure that you save the project before regenerating the mesh?
Let me know if this did the trick!
For more information, please watch the video and follow the steps on How to edit the point cloud in the rayCloud again and see if there are any differences made this time.
If not, please contact the support team for further support.
Hi Christina …thanks for replying
Yeah i did saved the project before regenerating mesh …nothing changed!
Hello @cilawif941,
As Christina said, you should be able to get a different model with the changes that you have made. First, assign the unwanted point cloud to the delete group, then save the project, and finally generate the 3D Textured Mesh. While generating the 3D Textured mesh don’t rerun step 2, use the methods explained in the below support article, Menu Process > Generate 3D Textured Mesh.
Hi Kapil_Khanal…thanks for replying
Yes that’s exactly what i did but same problem come out
