I’m processing some thermal and RBG data from a Zenmuse xt2 camera.
The thermal data has been processed using the Advanced Thermal Camera settings, while the RBG I used standard 3d Maps in PIX4DMAPPER.
When I open the RGB map (from the ‘DSM/Mosaic’ output folder) and the thermal reflectance map in QGIS, there is a mismatch - it looks like a slight scale mismatch as well as the RGB images having a slightly wider field of view.
I want to have these aligned perfectly to load into a KMZ google earth file
I wonder if I have a setting wrong on the thermal data? When I open the tifs in python they have the following metadata :
Metadata of thermal reflectance TIFF file:
Extent: (669333.05067, 1148309.08063, 669856.80637, 1148785.60657)
CRS: PROJCS[“WGS 84 / UTM zone 16N”,GEOGCS[“WGS 84”,DATUM[“WGS_1984”,SPHEROID[“WGS 84”,6378137,298.257223563,AUTHORITY[“EPSG”,“7030”]],AUTHORITY[“EPSG”,“6326”]],PRIMEM[“Greenwich”,0,AUTHORITY[“EPSG”,“8901”]],UNIT[“degree”,0.0174532925199433,AUTHORITY[“EPSG”,“9122”]],AUTHORITY[“EPSG”,“4326”]],PROJECTION[“Transverse_Mercator”],PARAMETER[“latitude_of_origin”,0],PARAMETER[“central_meridian”,-87],PARAMETER[“scale_factor”,0.9996],PARAMETER[“false_easting”,500000],PARAMETER[“false_northing”,0],UNIT[“metre”,1,AUTHORITY[“EPSG”,“9001”]],AXIS[“Easting”,EAST],AXIS[“Northing”,NORTH],AUTHORITY[“EPSG”,“32616”]]
AREA_OR_POINT : Area
TIFFTAG_SOFTWARE : pix4dmapper
Metadata of RGB mosaic TIFF file:
Extent: (669245.15998, 1148244.38526, 669872.58472, 1148830.96884)
