I am trying to process step 1… on a computer where I have recently successfully processed similar size projects. Each time I attempt this, the computer turns off before step 1 finishes. I’ve tested many scenarios and am confident this is happing due to the processing and that my computer is not turning off for some other reason.
The end of the log file always reads something like this:
[2021.01.27 04:12:37][ 46%RAM][ 0%CPU][Info]: Matched pair 50354: <2018-9-29(GMT)_Fog_rededge_0000SET_006_IMG_1247_2.tif(6236,10000),2018-9-29(GMT)_Fog_rededge_0000SET_006_IMG_1252_4.tif(6263,10000)>: nrMatches 214 | GPU 0 GeForce MX150
[2021.01.27 04:12:37][ 46%RAM][ 21%CPU][Info]: >>><<< done in 01s:503ms / 0.02505 min.
[2021.01.27 04:12:37][ 46%RAM][ 21%CPU][Info]: Add matches
[2021.01.27 04:12:43][ 46%RAM][ 16%CPU][Processing]: Add matches.
[2021.01.27 04:12:43][ 46%RAM][ 16%CPU][Info]: Add points to tracks allSize: 1944833 recSize: 520728 the: 0.0603861, 16
[2021.01.27 04:12:47][ 46%RAM][ 14%CPU][Info]: NrNew: 3831 nrAdd: 197840 from: 55 images
[2021.01.27 04:12:48][ 46%RAM][ 14%CPU][Info]: Find more tracks error: 0.655971 nrProjections: 4024066 nrTracks: 524559 trackSize: 524559 s0(0) s1(0) s2(196671) s3(82402) s4(45711) s5(199775)
[2021.01.27 04:16:26][ 46%RAM][ 93%CPU][UI]: Closing Project.
[2021.01.27 04:16:26][ 46%RAM][ 93%CPU][UI]: Question q0018: Closing the project will stop the processing. Do you want to close the project?
Hello Kerri,
Would you please update to the latest version and let us know if the problem persists? At that time, I’d appreciate it if you could upload the entire log file, the quality report, and give us information about your hardware specs (RAM, CPU, available hard disk drive, etc) to investigate the issue. Thanks!
