Rarely do I ever merge projects, but this past month I’ve done it twice.
Both times, after re-optimizing the project, I would have 2 layers of bundle blocks.
I noticed that I would only run Step 1 for each project and then merge them.
Would running Steps 1 and 2, provide a better merged project result?
Or does it even matter?
Hi Jason,
Processing step 1 and step 2 doesn’t provide better merged result. The merged result would be the same. If you are having two layers, after merging, I would recommend you to add 3-4 manual tie points and reoptimize your project. This should solve your issue. For more information, I would recommend you to follow the steps explained in our support article; How to merge projects.
