I have produced a quality report but when i try print it is greyed out, how can i print this quality report.
It also never saved as a pdf file it saved the report in a xml format.
How can I sort this problem out.
which Pix4Dmapper version are you using?
Version 4.6.4
Thank you for the additional information.
It is weird the report is not exported in pdf format. Does this happen with all projects or just 1 project?
To further investigate, please send us the log file of your project:
Please also make sure you have the minimum hardware requirements:
and that the drivers of your graphics card are updated.
I have the same problem. The PDF button is greyed out and could not print the quality report. Pix4dmapper ver 4.6.4 running in Windows 10 Pro. Please advise solution
Would you please try to open the index.html file with your browser and then use the “print to PDF” function to see if it works?
Kind regards,
Thank you Yuka, that worked.
