I have a large area I have mapped with a Phantom4Pro RTK. I have processed the area in two seperate files and plan to merge them. I am going to use a processing area on both projects to trim out the area I dont need. I was wondering at what point do I add the processing area to each project? I have run step 1, added my GCP and manual tie points for the merge. After I have reoptimized both projects do I add the processing are to each one, then move forward with the merge? Thank you, Nathan
Ciao @nathan.guessetto,
Welcome to the Pix4D Community
If you want to combine two projects, it is important that you have enough overlap between them.
You can find more information about merging projects here:
I suggest you add the processing area for the entire project after you merge the two sub-projects.
In fact, the processing area has no effect on the results of step 1, as explained here:
https://support.pix4d.com/hc/en-us/articles/202560179-How-to-use-a-processing-area-in-Pix4Dmapper#label1
Please let me know if there is anything else that I can do for you.
Merge them first. The data you’re trimming in the “merge area” will only help to bolster your datasets when you rematch/optimize. Draw a processing area after you merge the projects. Then Rm/optimize. Don’t forget to check to ensure that your processing options, output coordinate systems & GCP coordinate systems are identical!
