Process P4 Multiespectral (RGB, RedEdge and NIR images)
Hi
I have RGB (just composed file, I don’t have the discrete bands), RedEdge, and NIR images from P4 Multispectral. I want to know if is possible to process them together and make a spectral index and ortomosaic.
Pix4D reported to me the error e0204a: Too many missing images leading to incomplete captures.
Example images:
your dataset has not enough images, make sure you have a dataset with sufficient overlap.
Could you please send us the following if you have a valid dataset available?
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf
▸ The project file (.p4d): …\project_name.p4d
▸ About 10 images of the project.
Julius
