Problem with external orientation of photos - DJI Zenmuse L3 and Pix4Dmapper
In Pix4Dmapper last version offers support for this cameras but doesn’t take correct external orientation of photos. The problem is with angle of the left and right photos. Is there method to adjast thiis photos in Pix4Dmapper?
Do you plan add true possition and orientation for this sensor?
Thanks for answar.
Hello @gsylwerski, You can edit the camera parameter using Image Properties Editor. For more info visit,
Can you explain with screenshot what you are referring and which camera model you are referring? If you are referring to camera geolocation and orientation parameter then those are using the XMP tags and if those tags are wrong on the metadata of the images then there is not much we can do.
Hi @gsylwerski,
I read that Pix4Dmatic is going to be supporting this sensor. After facing the same issue, we found that the roll offset was not included in the Exif metadata. Seemingly DJI Terra adds an offset from the gimbal for each LV and RV camera.
As a workaround, we used ExifTools to extract the gimbal angle and apply a +/-22.5° offset and either export a text file, or input back into the image Exif metadata. If anyone wants further information, please feel free to reach out at jason@geodronesurvey.com
