Problem in generating orthomosaic
 There are some gaps/error in generated orthomosaic. Please take a look.
http://www.fileconvoy.com/dfl.php?id=g53470c063c94dd31100007737061daeedf78ebda6a
Hi Rohini,
Could you please also share the quality report of the project and a screenshot of the rayCloud with the densified point cloud loaded?
Hi Julie,
Here I have attached the quality report and Screenshot of the rayCloud…
http://www.fileconvoy.com/dfl.php?id=gd012e1bde8ab521a10000774331538c01ec1c928a2
Overlap isn’t sufficient in those areas. This screen cap was taken from your quality report and you can clearly see those red areas where there’s no enough overlap.
Hi Jaakko,
Thanks for your Reply… Hope I will sort it out the problem.
