Hi-
intending to fly a mission next week in LA area and I live in New York-
Just tried out the app and pretty happy with results -
wanted to drop the mission planner grid image on a location in La before flying out-
is there a way to do this without having to drag the grid from NY to La?
Hi Patrick,
This article will probably helps you: https://support.pix4d.com/hc/en-us/articles/115001609983
Hey thanks-
Checked the article-
Seems all command are to geotag the area you are standing in-
It would be nice if you added a zoom the mission to where you are focused on the map button-
Dragging the flight plan across the country was tedious but worked-
On a good note screenshots of the intended plan for flight patterns intended went over really well with the rangers office and i only had to drag the grid across the country once… just had to be careful not to hit the reset button-
Best
P
