Good Morning,
Yesterday, our team did not have a good experience testing the Pix4DMatic software… First, while this is not just a matic specific problem, we had a flyaway where our drone decided to try to create a map about a mile away from its assigned mission… If it wasn’t for me chasing the drone in my car at 60mph, it would be gone…
As per the flyaway, I later found that a background process in Pix4DCapture was trying to upload images from the drone was causing the application to crash and causing extreme battery drain… When the drone took off for the mission, the app crashed but quickly restarted, and it looked as if the drone was still flying to the starting location… but kept going, and the Abort process failed…
Then, when I took the new images that we had collected on a mission before the incident, and upload to Pix4Dmatic to combine with a previous flight… All the images appear in alignment, but when I calibrate the whole project turns sideways, and I cant seem to figure out a way to fix this issue…
My best guess is that the different flight altitudes, are messing us the calibration process somehow, but I don’t think that should be a problem…
Here is a screenshot of the issue: https://gyazo.com/d2eec9b5e68fa10c85b4b9aa3df825f1
Any ideas?
Thank you,
CJ
