[PIX4Dmapper] Skydio 2+ camera parameters
I own a Skydio 2+: is there anyone who knows the correct camera parameters to be inserted in Pix4dmapper database?
Hi Antonio,
The Skydio 2+ can be found in PIX4Dmapper’s internal database:
Im trying to use my skydio 2+ with pix4d but it doesnt come up under a drone i can use
Hi @real3stshooters
Welcome to the Pix4D Community.
Are you referring to PIX4Dmapper software? Can you eventually share the quality report with us?
Yes, I’m using the pix4dmapper software with the skydio 2+. But it’s not showing up as a drone I can use for the flight planning
Thank you for your reply.
Which flight planning app are you using?
Please note that this drone is not available for PIX4Dcapture or PIX4Dcapture Pro.
It’s pix4dmapper, I went to flight planning tab and it only had parrot and dji drones available for me to select as my camera and or drone
Hi @real3stshooters,
PIX4Dmapper is a photogrammetry software:
PIX4Dcapture Pro is a flight planning app:
Skydio 2+ can be used in PIX4Dmapper for photogrammetric processing, but you can’t use PIX4Dcapture Pro to capture images as this drone is not supported:
You will need to use another app to acquire images.
Please let me know if this information helps you and if there is anything else I can do for you.
Daniele
Why you can’t implement Skydio 2 or Skydio 2+ in Pix4dCapture Pro?
