Hi, trying a circular mission with my Bebop2 drone, it seems impossible to start the mission if the flight height is lower thant 30 meters. how ti get around this restriction?
Rgds
Denise
Try switching the measurement to imperial, and fly in feet. Also I believe you can still fly the drone but you can capture manually. The drone will take photos every x amount of feet but you fly in circles around the structure yourself. I hope this helps!
Hi thank you for this answer. I will try. However it’s a pity not having this possibility with circular missions (even if I understand why)
