The interface for inserting drawings could use a lot of improvement. Typically we’re overlaying to-scale drawings. The drawings are coming in square instead of the aspect ratio that they should be. To scale it, you have to drag out the 4 corners of the drawing individually. I understand that it’s nice to be able to skew the drawing if needed, but 99% of the time it will not need to be and should maintain its original aspect ratio.
How can I share orthoimages with the overlay drawings?
How can I overlay several different drawings and toggle them off and on as needed?
What if a drawing is updated? Do I have to realign it from scratch or can I update a drawing that’s already there?
How do I delete drawings?
