Hello
Please assist, for the image values, what units does pix4D use?
Thank you,
Snethemba
Hello
Thank you,
Snethemba
May I ask if you are referring to the image coordinates (i.e. lat,lon) or the image orientation (omega, phi, kappa)?
The pixel values.
The value of each individual pixel will depend on what type of raster image you are working with. For example, if you are looking at the digital surface model then each pixel value represents the elevation of the surface where the pixel is located. If you are looking at multispectral imagery then the pixel value will represent wavelengths ranges across the electromagnetic spectrum. I think you need to be a little more specific in your question.
