Good morning,
I’m working on a project and I need to obtain a raster map of a field, where I took picture with DJI P4M, and include reflectance value of each pixel.
Is there a way to obtain the result?
Thanks a lot
Giuseppe
Hey,
You can process the images in PIX4Dmapper and then export the reflectance maps to third-party software to extract the pixel values. You can use for example Matlab or QGIS. In case you have PIX4Dfields, you can get the pixel value when you create an annotation See here: https://support.pix4d.com/hc/en-us/articles/360045667212
