Pix4D Textured Mesh -> Arcscene or ArcGIS Pro
Has anyone successfully gotten displayed a textured mesh in an esri product? I’ve tried following the workflow from Photoscan, which can export a georeferenced mesh.
https://www.youtube.com/watch?v=ScQWurJfRjQ
However Pix4D loses georeferencing on textured meshes. It is a simple offset found in the parameters folder to correct the location of the mesh, but I cannot get the texture into arcscene for the life of me. I just get an empty multipatch. Has anyone had luck with this?
Thanks!
Scott
Hello Scott,
We are not familiar with the process as we have not tested it from our side. Do you have the jpg file with the texture that is exported from Pix4D in the same folder with the mesh file you try to import?
In case that this does not work you could maybe try to contact the ESRI support for further assistance, as they are probably more familiar with importing various types of files in their software.
I have the same question. Any solutions?
Nathan - I did finally get it to work. You need to export the mesh from pix4d after the processing is over, click the LOD mesh option, and select SLPK. I was able to open the mesh in arcgis pro.
Where is this option? I am struggling to export a georeferenced mesh.
Hi @j.niles ,
Welcome to Pix4D Community!
Please follow these instructions: How to export the 3D textured mesh
I hope this information was useful for you.
have a very nice day!
Best regards
