How to import Pix4d 3D model into Arcscene and AutoCAD 3D Map ? I tried to import .obj and .fbx into Autocad only mesh was imported without texture ,same happened for ArcScene also ? Can you help to find solution ?
Hi ![]()
Please have a look at our article How to import Pix4D outputs to AutoCAD and the Pix4D Webinar: Using Pix4Dmapper outputs in CAD software from the 10:00 min you will see in practice how to open the 3D Textured Mesh in Autodesk 3ds Max.
Cheers!
