pix4d mapper
Map not up to date my house has been built 2 years and not on map can you update map
If the resolution is not satisfying or the content not recent enough with satellite data you could switch to the map background (OpenStreetMap), or even to the orthomosaic background once you ran step 3 and generated the output. The precision will be much better but the surroundings will not be displayed.
Have a look to this article for these settings: https://support.pix4d.com/hc/en-us/articles/202557719
However it is not possible to change the satellite background to another provider at the moment.
Note that your image geolocation on the Map View is as accurate as your geotags.
