Pix4d mapper trial activation
Hi, I am not able to receive activation code for trial version for Pix4d mapper. And what are the limitations in trial version of Ppix4d mapper?
Hi @zeeshan.ibrar it seems you successfully started a PIX4Dmatic trial! There are no limitations when using a PIX4Dmatic trial, so do not hesitate to contact us if you have any questions or get any unexpected results. Cheers, Rhéa
Yes, but I wanted to try Pix4d mapper. I am not able to activate trial version for that.
Hi @zeeshan.ibrar you can see how to get a trial here, but I recommend PIX4Dmatic in most cases.
Can you give me more information about your projects so that we can determine the best solution for you?
  • What do you need to achieve?
  • What type of outputs do you need?
  • What hardware do you use?
  • What type of images do you need to process: RGB, thermal, or multispectral?
Hi Garatt
Thanks for reaching out.
I want to develop DTM instead of DSM and then to create contours. PIX4DMatic does not give this option. I am processing RGM images for Drone. I have contacted for trial version of mapper but not received any response.
