After starting a volume measurement in Cloud, if you try to rotate the view it stops the volume calculation. It’s critical to be able to rotate around a stockpile in order to draw the volume boundary correct the first time. Otherwise you have to draw the shape then head into the edit screen.
Hi Tylor,
I see what you mean. While we try to fix this, you can rotate the 3D view while drawing a volume if you press Ctrl + left clik.
Cheers
Hi Tylor, this has been fixed and will be made available soon, most likely early next week.
All the best,
Hugo Campos
