Pix4D Capture - Mission unable to start.
I’m hoping this has been answered and I’m simply having trouble finding the solution…
We picked up the Parrot ANAFI USA Gov platform for the sole reason that it is on the bluelist. I have tried repeatedly to run grid-based autonomous missions with Pix4D Capture and have had no luck. I can create the mission, save it. When I go to fly, everything (seemingly) is pushed to the ANAFI (all green checks), and when I hit launch, it returns “Pix4D Unable to Start Mission”. This is incredibly frustrating. I have tried force quitting the app, turning everything off/on, etc. I get exactly the same result every.single.time. I would welcome any suggestions that can get the ANAFI and Pix4D to play well together…
Hello there, Are you using PIX4Dcapture or PIX4Dcapture Pro? I recommend tying PIX4Dcapture Pro and see if that helps. If you still have the issue, send the screenshot of the issue so that we can look into it.
I have the same issue. Im using the Anafi Thermal. Ive tried on my iphone, iphad and perosnal phone which is a andriod Pixel 9 pro. Same results. Very frustrating as well. any solution to this question?
Experience similar issue with my Inspire 2. I repeatedly uninstalled-installed-clear cache-clear data the Pix4D Capture old version, 4.5, and version 4.11.
Maybe someone have the best solution to resolve the problem?
Thank you
