Picture orientation problems for a newbie
Hi.
Im evaluating pix4d mapper and comparing it to Autodesk ReCap etc.
When try to do a mosaic from a drone, the picture orientation goes crazy. This is not a problem in any other program.
What am i doing wrong? And what is this problem called?
Pictures taken straight down from a stable platform, so all pictures should be in a straight line. Alot of overlap.
Hi Johan. We would need to take a look at the quality report to determine a cause but you may be able to fixs the issue by setting your image vertical accuracies to 0.1m and selecting accurate geolocation and orientation for your step 1 calibration method. If you find that doesn’t work then try opening a support request by clicking contact support and send us a copy of the quality report.
