Parallel processing in pix4d mapper
Hi
Is parallel processing capability is there in pix4d mapper, ex. If i have 2 licences can i use compputer resources viz. CPU/GPU of 2 work station connected in LAN to speed up the process especially tie point generation…i
Thank you for your time
–kindly suggest
Hi @narender.bommineni,
Thank you for sharing your request with us.
PIX4Dmapper cannot distribute processing over multiple computers. However, it is optimized to take advantage of multi-Cores and multi-Processors.
You can find additional information at the end of this article:
