Thank you for this amazing app. I am using a Nexus 7 with a DJI Phantom 3 professional.
I have some comments/questions.
Camera angle setting is off. I set the camera to be completely vertical (90 degrees) but when I processed the pictures with pix4dmapper it told me that the pictures where taken with a 70 degrees instead.
“Lage”, “Too Large” calculations. With the setting of “medium” overlap, at an altitude of 50m, a region of 433 x 193 is deemed “TOO LARGE” with an estimated time of 10min:06sec. However, a region of 433 x 207 is deemed only “LARGE” with an estimated time of 9min:41sec
“Reset” area resets zoom setting as well. This is kind of annoying when viewing the map in satellite mode. In the region I am, the satellite imagery is not available for the zoom level it is resetting, so we end up in an ugly black looking map. It would be better if:
a. the reset button only changed the location/and size of the region, or
b. If it also changed the view, also change to map view, or
c. if in satellite mode, then check what is the highest zoom level available and reset to that level
Thank you.
Ioannis Demetriou
