I am experiencing a recurring issue with the program. While it initially worked perfectly, in the last orthomosaics I have generated, a blurry line appears in the direction in which the images are taken.
I have tested different parameters for the Mavic 3M, but the results have always been the same. This blurry line affects the processing, as Magic Tool detects it as a distinct area. I am attaching two images: one showing the blurry area and another with the detection performed by Magic Tool.
So far, I have generated approximately 10 orthomosaics, and the problem persists in all cases. The overlap used has been 70% lateral and 80% frontal.
Could you help me identify the cause of the problem and how to resolve it?
