I use the Pix4D cloud, not advance. How can I make a orthomosaic of a facade? Is it also possible to generate a elevation profile of the facade?
Thanks for helping
Thanks for helping
Hi @nikolai,
You should be able to generate an orthomosaic of a facade on Pix4Dcloud. Ensure the images strictly point to the facade and do not acquire background information. For advanced options, I would suggest instead using Pix4Dmapper. More information in How to create the orthomosaic of a facade.
Regarding the possibility of generating an elevation profile, measurements, therefore an elevation profile, cannot be performed on projects whose average GSD is inferior to 1 mm at the current status of the Pix4Dcloud application.
