I recently created an ortho using Pix4D. I am trying to write a program that projects an image point onto the orthophoto. Does anyone know exactly what equations I have to use. I know they should be collinearity equations, but I am not sure about the conventions (coordinate systems, orientation angles and the order they are used to form the orientaiton matrix) pix4d uses.
If I understand well, you want to click on a point in one image and get its correspondence in the ortho.
If that is the case, what you have to do is:
Compute the “ray” which is defined by the projection center and the point you click in the image. You need the interior and exterior orientation to compute that “ray”.
Intersect that “ray” with the DTM/DSM which was used for the orthorectification and compute the X,Y coordinates of the intersection point.
Please note that if you use a DTM instead of a DSM, a point on the top of a building will be located in different positions depending on the photo you click.
Thank you. Yes that is exactly what I want to do. The only thing I need are the equations. In other words, I am going to get the orientation parameters, which are the internal and external parameters computed by Pix4D, and put them into collinearity equations you have used. I just need them or other form of equations you use in Pix4D, so when I say insert a ground point coordinates into the equations, I will be able to get the corresponding image coordinates.
The only trouble I have is that I do not know exactly, what equations you use. Could you please help me?
You can find the photocoordinates (x,y) of a point in the terrain (X,Y,Z) by knowing the external and internal orientations of the photo.
I guess that is what you want.
External parameters (position and rotations of each camera) and rotations can be found in the file …calibrated__camera_parameters.txt located at …\1_initial\params
I hope this information helps you.
Regards.
Cookie Policy
