Hello, I am getting an error when exporting 3D textures, do I need a computer with 179GB RAM to export? Thanks!
Hi @work
From the piece of the log file you shared, the memory left seems to be 16GB.
Depending on the size of your dataset and the image resolution, 16GB may not be enough.
You can check out here based on the size of your dataset:
System requirements: Minimum and recommended computer specifications
If you could share the entire log file, it will be more helpful!
Menu View > Log Output
I hope this helps. ![]()
Sincerely,
Rosana (she/her)
ym.log (358.2 KB)
Hi, this is my log file and 32G of memory is not even enough? According to the error message it needs 180G of RAM, who normally configures that much RAM? Is it better to chunk the task of generating LOD? Is there any other solution than increasing the memory? Thanks!
Hi @work
I would suggest you split the project into subprojects if it is possible.
Like this, you won’t need this much ram to process all the images at once.
I hope this information helps you.
Have a very nice day!
best regards
