hi,all
a question about that
if i want to generate different type of DTM contour(ie.different resolution or different interval).
can i only run the step “Generate DTM”–>“Generate Contour Line”
Or i need to run the entire step.3 ?
thanks
Best regard
hi,all
thanks
Best regard
If you modify the parameters of the contour lines in the processing options:
and you have already generated a DTM previously, you can generate the contour lines from the same DTM with Process > Generate Contour Lines (DTM). This will be faster than regenerating step 3 entirely every time.
