Multispectral Processing
Trying to process around 8700 pictures in pix4dfields, they’re multispectral images. I was using a computer with i5 and 8gb ram, which I know is less than what’s recommended. It would reach 40%, then stop and wouldn’t go any further. I borrowed someone else’s computer that has 16gb ram and the same thing is happening. I processed the orthomosaic map and it did it with no problems, it just won’t do the multispectral. Do I just not have enough memory so it’s stopping at 40%? I find it weird that it stopped in the same spot on both computers. Any help is appreciated!
Are you canceling the process? you need to leave it and see what happens. If it’s crashing , please share the log files.
Go to Export, Log Files.
Jose
