In most of the cases, this error appears when there is not enough RAM for processing. However, please send us the .log file that we could look more closely at this problem. You can use our OneDrive to store the file.
Hi Alan. Given that the project is over 50,000 images and the images are 3840x2160 the hardware resources you have described are definitely insufficient for such a massive dataset. This size dataset would require server grade hardware to process in its entirety. You will likely need to split it up to generate the outputs as smaller pieces and then merge together in another application. For example, if you are interested in an ortho then you can generate the sub-projects (~3000-5000 image chunks) and then merge the orthos generated in GIS. If you want a mesh then you can merge the point clouds and generate it in a free application like cloud compare.
Pix4D may be able to get through steps 1 and 2 possibly. Step 3 will likely not succeed because the point cloud DSM needs to be loaded into memory in its entirety and that will either exceed your available RAM or leave you with too little room for generating the rater outputs.
Hi Alan. The maximum amount of RAM that I am aware of for workstation grade computers is 256GB but 128 GB is more common. Im not sure that even with that much you will be able to successfully process step 3 for all your images. It will depend on the processing options as well as the number of images. More likely you will still need to split into sub-projects but the benefit of more RAM would be that the subproject could be larger and thus would require less manual work. Exactly how big will vary project by project. You will need to test what your system is capable of processing given your image dataset and the processing options required by your project needs.
Your project should be able to complete processing if your license expires during a project.
