I have two fisheye cameras rigidly mounted on a rig with GPS and I would like to process them together with Pix4D.
How can I manually configure a rig composed of two cameras? I know an approximate relative orientation of the two cameras (boresight) which I also would like to refine. I cannot find how to do it in the Pix4D mapper for linux. Is this possible?
Thanks for the support
Hello Davide,
This link contains all the information on how to create a process a rig and the different parameters you can apply: Processing rig cameras
You need the boresight and the distances between them. You can also refine them by using different computation modes but the recommendation is to have a good initial definition. in addition if you want to compute all of the parameters, you need some GCPs.
Regards.
