MTP during Merge
I would like to know what I have to choose in the questions as the immages that I have attached.
I have several sub-projects that I have to merge in one big project and I already signed several MTP’s in each sub-project but NOT ALWAYS the same in common between projects. Several MTP’s are not in common so I’m not sure about what to do in this case.
Thank you for attention and best regards.
Roberto
Hi Roby,
When merging two projects, you need to have the same MTPs with the same name in both sub-projects.
You should then click YES for both warning messages you get. This will allow the software to bind the two sub-projects together as explained in the following training video : https://youtu.be/Wu-A64egnb4?t=627
Having other MTPs which are not common to both sub-projects is not a problem, they just won’t be used for the merging.
