how to do make a mission in a place where have a lagoon.
In first instance y made a mission and the pix4D dont calibrate some pictures in the water, so i dont have image in some places of the orthomosaic
i read that i’ll have a mission parallel to the fisrt mission and higher, somebody can confirm that information?
Hi nibaceta,
Trying to map water is very difficult. You will want to fly as high as possible and have very high overlap. Perhaps 80-90%. Ideally, you do not want images that only contain water. It is best if the images contain some land as it will greatly help calibrate the images. I hope this helps.
