I have this plot that I need to process by splitting the project into subprojects. The problem I have is that the GCPs, marked with the blue X, are not dispersed enough to fit in all sub projects. I know you need at least 3 per subproject, but this will not be the case for this plot. Will this be a problem once I merge the projects together at the end? Thanks!
