Hi Christina
O am new to pix4d and learning the system with a small project of a deck area. The issue i am having is that three sides of the deck i.e. walls appeared in the point cloud and mesh but the 4th side i.e. fence did not.
As a check I then created another project with the same photographs just for the fence and they were modelled. Therefore I can’t understand why they did not model in the 1st project.
I then decided to merge both project but I keep getting the W0009 warning coordinate output values are not the same. I am not using any GPC - only MTP. However as it is only a deck area and I am using a DJI phantom 4 pro I dont believe I need a GPC .
My final question is: if a GPC is required how would I attain that as I don’t have any of the control matts or the RTK software etc. Is there another way to establish a GPC?
