Mavic3T and processing image
Good morning everyone,
I wanted to ask if the thermal images with metadata captured by the DJI M3T can be processed directly by Pix4dmapper or do they have to be converted into Tiff images?
Best Regards
Giorgio
Hello Giorgio,
Mapper cannot radiometrically process the thermal images from the M3T. It can process the thermal images as a standard RGB image. Basically, it can make a pretty map, but it will not contain accurate temperature information.
For a workaround, you can use a third-party software called ATygeo to convert the images to a compatible format for radiometric processing.
HI,thanks so much for the information.
Best Regards
Giorgio
