I have some uncalibrated images to deal with. Most have at least 2 or 3 GCP’s showing up in them. Is it possible to mark GCP’s within the selection window? It would save a lot of time if I don’t have to select a GCP and scroll through the images.
I would recommend to manually calibrate the images as it is explained in this article: How to manually calibrate uncalibrated cameras in therayCloud.
Once they have been calibrated, you can easily measure the GCPs.
Anyway, If you use the basic editor to measure some GCPs and rematch and reoptmize afterward, it is very likely that the images will get calibrated and it is probably faster than calibrated manually.
Regards.
