mark export function
Hello.
I use ‘mark import’ function when using mark-data from PIX4Dmapper.
But export function is not on PIX4Dmatic.
If I want to exchange mark-data from PIX4Dmatic to PIX4Dmatic (sometime PIX4Dmapper), there is no ‘mark export’ function.
I expect to add export function.
Best Regards,
Seiichi Takayama
Hello seiichi_takayama,
I would suggest visiting our feature request page for PIX4Dmatic. You can enter your request for the export function there.
Thank you!
Hi @seiichi_takayama , which version of PIX4Dmatic are you using? We’ve added the export/import of MTP marks and have improved the export/import of GCP and Checkpoint marks in version 1.21.1: https://www.pix4d.com/download/pix4dmatic
If the issue persists with that version, please let us know in more detail when exactly the “mark export” is missing.
Thank you
Dear @Pierangelo_Rothenbuhler
I used version 1.20.0.
I didn’t notice new version.
I will try !
Thank you.
Best Regards
Seiichi Takayama
