Low altitude
I favorited Pix4D Capture.It is very cool.
I’m used to fly  at altitude 10 to 15 meters.
I am unable to upload the Mission to my P3pro.
Warning is “The  altitude is quite low. Make sure you know how to take the manual control and  beware obstacles”
How to fly at low altitude?
Hi Akihito,
Thank you for the nice feedback.
There is indeed a bug that is now fixed in the iOS version that we are about to release in the coming days.
The App Store will probably notify you.
We apologize for the inconvenience in the meantime.
Hi Juilie and Akhito,
Im currently using double grid for 3D models, but I cannot reduce the altitude below 30m, if I reduce it I get the low altitude warning.
Can I still start the mission?
Borja
Yes, you can still fly the mission. We just recommend to be careful with the potential obstacles and to have have a sufficient overlap.
Dear Julie,
I have the same problem, I couldn’t fly lower with the pix4cap, then 30m.
Is any solution?
Hello @erdei.andras,
The minimum flight height you can set for the DJI drone is 10m. You can change the flight height by scrolling the number bar as shown in the figure below.
