Load Optimized Parameters option grayed out
The " Load Optimized Parameters" option is grayed out and not sure how to access it. Any advice?
Thanks!
Dear Lawrence,
Did you run the first step of processing? This is necessary for the optimized parameters to be computed.
After running the first step, you will need to edit the camera model to be able to load the optimized camera parameters.
I have had this same issue the last several projects and Cannot figure it out.  Run first step, immediately go in to create the new camera model with optimized parameters and it’s grayed out.
Have you clicked the Edit button below the camera model name?
Once you click it, it should look like this:
