I have a 160gb las file produced yet when I load it into cloud compare only around 1/4 of the points are loading in, is there any way to fix this?
Hi @mick,
Have you checked what is the limit size of files you can import into ClouCompare?
I believe the issue you are experiencing is related to the file size. You could try cleaning up the pointcloud to remove noise and reduce the size of the generated file.
Please have a look also at CloudCompare forums.
Best
