Hi, may I know what’s the difference between of these 2 template? Large Scale Corridor vs Map. Our terrain are mountains. Which template should we use for a better results? Thank you.
Hello!
“Large scale and corridor” template is faster for projects with many images, e.g., containing one thousand or more images, and it works generally well; while the “Map” template can handle more challenging projects (non-optimal image overlap, homogeneous image content), but might be slower to complete. If your projects don’t have many images then you can start with the Map template, otherwise we recommend to start with “Large scale and corridor” template.
Hope it helps.
Kind regards,
Alexey
Thank you, Alexey. One more thing is it possible we can disable the uncalibrated images in pix4dmatic like in pix4dmapper? Thank you for your unwavering support.
Hello!
At the moment it is only possible to remove images from the project, disabling them like in PIX4Dmapper is not yet supported.
Kind regards,
Alexey
