Which is better matic h or mapper
Do you think pix4dmatic is better than pix4d mapper?
Answering this question can be very tricky as the concrete answer depends on each user’s needs and requirements.
PIX4Dmatic and PIX4Dmapper each have their strengths. PIX4Dmatic is particularly efficient for large-scale and corridor projects, processing datasets with more than 5000 images significantly faster than PIX4Dmapper. It also excels in generating DSMs and orthomosaics efficiently. It also provides support for local geoids for example and many more features. On the other hand, PIX4Dmapper supports thermal and multispectral imagery which are not available in PIX4Dmatic yet. The choice between the two should be based on specific project needs and workflows.
Spachos
