I am struggling to import tracks such as existing levees and poly pipe runs into JD Ops Center and then transfer to a GS3 2630. Is there a place to find basic info on utilizing Pix4DFields maps in John Deere Ops Center? A breakdown of the steps for importing everything from boundaries to tracks would be great. Thanks.
Hi, thank you for your comment-
May I ask what you are doing with this information within PIX4Dfields?
You can upload boundaries, HD orthos, and prescriptions maps to JDeere within PIX4Dfields.
Please read How to connect to John Deere Operations Center from PIX4Dfields
I am using a Mavic 3E to map agricultural fields to mark boundaries, obstacles, and save existing irrigation levees and poly pipe runs. I am able to import the boundaries into JD Ops fairly easily, but when saving the levees and poly runs as tracks, I am struggling to get them into JD Ops. The end goal is to be able to recreate the levees and poly runs with with the JD guidance system. The fields are all flown using RTK and and the tractors are equipped with JD guidance systems.
Thank you for explaining your workflow.
We might be able to provide a solution for this use case, I will send an email to follow up.
I was able to find a work around and import my guidance lines into T3RRA Design and export to John Deere Ops Center. My next issue is not being able to import a DSM into T3RRA Design from Pix4DFields. Any suggestions?
(attachments)
applicationLog.log (422 KB)
4601d5ec-d0b7-4b41-ace7-7b19b1645a9c_logfile.log (2.26 MB)
Caney PDF.pdf (282 KB)
