John Deere / MicaSense Service Provider / Ireland
I’m surfing for information with regards to the integration of data collected via the MicaSense, and the John Deere. Your experience, best practice, file transfer. Thank you for reading
How do you delete this post
There is currently no integration between the John Deere Operations Center and PIX4Dfields or PIX4Dmapper. However you can export a variable application map which can be imported into a tractor terminal.
https://support.pix4d.com/hc/en-us/articles/360038644731-How-to-export-a-variable-application-rate-map-of-Pix4Dfields-to-a-tractor-terminal
If you need to delete then click on the tree dots at the bottom of your post.
We now have a new integration with John Deere since PIX4Dfields 2.5:
You can find the technical documentation here:
