Issues with the images uploaded to sofware
Hello.
I used Pix4D mapper for uploading drone images taken from a bridge. While all the images look correct in the dataset, images in the software look inverted after the “Initial Analysis.” Even after the analysis, the 3D model looks distorted with gaps in the 3D model.
Can someone please help me how to solve this issue.
Thanks and Best
Can you attach your quality report to this posting?
This the Image after generating final 3D model. It has some elevation problems as shown in the image. I’m also attaching the report here.
Thank you,
US 79 190 Nadir Images_report.pdf (321.3 KB)
Full support for the Skydio X10 came in version 4.9.0. I highly suggest upgrading to the latest version so that this drone processes correctly.
OK. Thanks a lot. I’ll try that one
Do we have any options for back face culling using Pix4D ? If so, can you please provide me with the required guidance and documentation? This is to create good 3D model of bridge deck on both sides.
Thank you,
Best Regards
Our next-generation photogrammetry software, PIX4Dmatic, fully supports back-face culling for the mesh. Unfortunately, PIX4Dmapper does not.
Got it,
Thank you so much,
So, to create a good 3D model for a bridge you would suggest pix4Dmatic? Or do i have any other alternatives? Can you please suggest me the best one?
Yes, I do suggest PIX4Dmatic. It contains more features that will work better for your needs.
Got it. Thank you so much.
Hello. I am planning to try with Pix4D matic. However, I already have pix4D mapper license. How can I convert my license to that software. However, Can I use the pix4D mapper license to login to higher versions? Currently I am using 4.8.4. can I use this license credentials to use 4.10.0 or 4.9.0?
Hi @vatsav0071
To log in to the latest version available to your license, please follow this procedure:
Ensure you log in with the account used to access PIX4Dmapper and select the organization that holds the license. If only version 4.8.4 appears for download, then you cannot use your license with higher versions.
Regarding the conversion of the PIX4Dmapper license to PIX4Dmatic, please reach out directly to our sales team here:
Make sure to explain your situation and needs, but I also suggest starting with a free 15-day trial.
Daniele
