pix4dmapper update for Matrice 4E camera
Can someone explain why are there no updates related to the program for a long time?
A lot of new models of drones and cameras have come out and the last update was in 2023…
During stage 1 processing, geolocation errors occur in photos…
We paid a lot of money for a program that is now unsupported, it does not show the company in a good light.
Hello @geodezja, PIX4Dmapper technically supports the processing of RGB images from any drone. The main requirement of the PIX4Dmapper software is that there should be enough image overlap while capturing the images to generate good-quality results. So, the problem is not related to the software not supporting the drone, it might be issue related to the metadata of the images or processing issue. Please send us the quality report and few screenshot to review the issue.
Thank you for response.
Please tell me why in DJI Terra the results on GCP are very good but on Pi4Dmapper it is not possible to record altitude flight? accurate to a meter
@geodezja you can download PIX4Dmapper version 4.10 here, released on May 15, 2025: Download Pix4D software. We have added more camera support. Which one do you use?
Regarding your altitude issue, can you provide more details? PIX4Dmapper will read the image geotags and derive your project’s position based on them. Using GCPs allows you to achieve higher absolute accuracy in your results.
